Search domain Fieldmaps
991
07-14-2023 03:27 AM
StaffanFridh
I work for a small company that does wildlife inventory and mainly use Fieldmaps.
To avoid misspellings in the field "Specie" i have set up a domain with common species that we're looking for (ca 8000).
The problem i have now is searching through this list when out in the field, i want the search function to search with the criteria Starts with instead of Contains. Ex: we have a specie called 'Al', i want it to filter out all species that start with 'Al' and not all that contain.
Is there a way of setting this up in arcgis online?
RhettZufelt
MVP Notable Contributor
Not sure if you can change this, but if your domain is sorted alphabetically, the "Starts With" values will appear at the top of the list.
R_
