Round Down Arcade
2212
08-03-2023 11:35 PM
yukler
Hi all, I'm looking for a way to round down in Arcade. I have used the round function which does simple rounding up or down and I've tried making the field integer type, which still rounds up or down. I'm doing field calculator and attribute rule work and am looking to round values down https://speedtest.vet/ . Thanks so much for the help!
DanPatterson
MVP Esteemed Contributor
in python if you can use the field calculator
import math
math.trunc(2.77)
the math module is available by default in the field calculator so you shouldn't have to use the import statement
... sort of retired...
JohannesLindner
You can use Floor() for that. The opposite (always round up) is Ceil().
Have a great day!
Johannes
