Rotate Polygon
264
02-08-2026 06:23 PM
MikeGordon74
I have this polygon created to represent a baseball diamond.  How do I rotate it around its center to match its physical orientation?
RPGIS
by MVP Regular Contributor
So there are two ways in which you can do this:
  1. Editing
    1. Start and edit session
    2. Use the rotate tool to rotate it accordingly
  2. Using a field
    1. You can set a value, as a double, and set the polygon to rotate according to that value.
