Rotate map viewer
4323
04-29-2022 10:21 AM
BrettGovernanti1
I've seen a bunch of posts on this but they are a couple years old and mostly refer to the Map Viewer Beta and how this functionality will be arriving soon to Map Viewer. So far, I've checked the road map and didn't see anything referring to rotation in Map Viewer. I also published with rotation but the rotation is not honored in Map Viewer. Does anyone know a way to rotate a map in Map Viewer?
jcarlson
MVP Alum
Right-click and hold, then drag.
If your map is rotated when you save it, it should load with the saved rotation.
- Josh Carlson
Kendall County GIS
jcarlson
MVP Alum
- Josh Carlson
Kendall County GIS
BrettGovernanti1
Beautiful! Thanks!
