Reverse legend
8664
7
01-27-2016 02:25 AM
EvaLopez_Martinez
Hi all. Is there a way to invert the order of the legend (data + symbology)? I am only interested in publishing one layer of the service in ArcGIS Online. The problem is the legend always gets displayed descending. I could invert the simbology manually, but not the data. Is there a way to do it or ESRI has still to implement that option? Thanks!
JayantaPoddar
MVP Alum
Eva,
If you are asking about sorting the attributes in Symbology, you could select all the values > Right-click > Reverse Sorting.
Think Location
EvaLopez_Martinez
Thanks for your answer Jayanta, I mean sorting the legend in ArcGIS Online, no Desktop.
I have several layers in one service, but I only want to publish one layer. The legend is always descending by default.
Thanks.
KyleBalke__GISP
Eva,
You can re-order the features in a layer in an ArcGIS Online map via the Change Style dialog...these changes should be reflected in the legend.
EvaLopez_Martinez
Hi Kyle. I have tried the Change Style dialog. But I don't finde the way to re-order it. I have graduated symbols and I am able to change manually these symbols. But cannot reverse the data. I don't know.
KyleBalke__GISP
Unfortunately I do not believe this is possible when using graduated symbols.
EvaLopez_Martinez
Ok. Thank you for your responses
KateřinaObrazová
Hi, in ArcGIS Pro I reverse symbol order, and then share it to ArcGIS Online.
Open in Map Viewer, click on Change style Dialog, click on Symbols (colours) and then here is a ''reverse symbol''.
Here is the official link with answer: https://doc.arcgis.com/en/arcgis-online/reference/styling-reference.htm
