Reordering fields in a web map
1175
07-24-2024 08:35 AM
Labels (2)
SLouq
by MVP Alum
I have a hosted feature layer which I want to be able to field workers on a tablet and am trying to reorder the fields in it. I know how to reorder the fields in configure pop up on the web map in ArcGIS Online but it is not transferring over to the tablet. Where do I need to reorder the fields in a webmap in ArcGIS Online so I can see it in the tablet?
Tags (1)
RussRoberts
Esri Notable Contributor
Table reordering in Map Viewer is not driven by the popup. We have plans to support this in an upcoming release. If you have a set order you want to display the table in you can do this with Experience Builder today.
EmilyGeo
Hi @SLouq
Yes, Russ is correct. However, if you want to re-order the fields in the form for data collection, you can create a form in Map Viewer. Check out this article to learn more about forms https://www.esri.com/arcgis-blog/products/arcgis-online/mapping/smart-forms-arent-just-for-field-map...
