Remove symbol class name from Map Viewer legend
2021
12-09-2021 03:10 PM
pkorst_coa
ArcGIS Pro 2.9 & AGOL Web Map
Hello,
I'd like to hide the symbol class name in the Map Viewer legend. For example, a polygon feature is uniquely symbolized by an attribute called "ZTYPE". I don't want to reveal the name "ZTYPE" anywhere.
If I blank-out the name (1) in ArcGIS Pro, the legend in ArcGIS Pro responds accordingly and removes the name. However, when I then publish that layer to Web Map, the name ZTYPE reappears (2). I have been unable to find a way in Web Map to remove it.
Q: How can I prevent the Map Viewer from displaying the symbol class name in the legend?
1) ArcGIS Pro 2.9 - Removed symbol class name correctly disappears from Legend:
2) Web Map Viewer - Removed Name incorrectly reappears in Legend and cannot be hidden:
Thanks for any help.
Tags (3)
ABishop
Hello,
Have you tried editing the fields for that layer?  I am not sure if you can remove the field name completely, but maybe rename it to something else?
Amanda Bishop, GISP
pkorst_coa
No. Renaming SDE database fields to overcome a limitation of AGOL is not feasible because GIS data is served to others in multiple departments, each with all of their own projects.
I am seeking a way to prevent the Map Viewer from displaying the symbol class name in the legend.
Thank you.
