Relationship Classes in Field Maps
12564
15
12-22-2021 02:06 AM
AdminWPZ
Hi all
From the Field Maps resources: https://doc.arcgis.com/en/field-maps/faq/requirements.htm
  • Related records
    "Feature-to-table relationships, feature-to-feature relationships, and table-to-table relationships (where the first table is accessed through a feature) are supported in Field Maps. For each, one-to-one and one-to-many relationships are supported. Relationships can be up to three levels deep. It is recommended that you use Global IDs when defining relationships. User-maintained relationships are not recommended."
The following case is described in the ArcGIS Pro Resources (https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/create-relationship-class.ht...😞
  • "Simple or peer-to-peer relationships involve two or more objects in the database that exist independently of each other. For example, in a railroad network, you might have railroad crossings that have one or more related signal lamps. However, a railroad crossing can exist without a signal lamp, and signal lamps exist on the railroad network where there are no railroad crossings. Simple relationships can have one-to-one, one-to-many, or many-to-many cardinality."
If I use a crossroad:signal lamp = 1:M cardinality Field Maps won't let me set points for independent signal lamps (the feature layer doesn't show up in the menu). How do I make this case with independent feature classes happen in Field Maps?
Caitlin_Todd_LCOR
Hi all,
Duncan, thank you for posting that solution! I never would've found that on my own since usually that functionality is configured within a web map.
I have a many-to-many relationship class I've published to AGOL and brought into Field Maps and I'm coming across a similar issue where my related records aren't showing in FieldMaps not even in the pop-up (even though it's set to show all related records), I tried implementing the solution above but it still didn't work.
Are Many-to-Many relationships not yet supported in FieldMaps?
AdminWPZ
Hi Caitlin,
This doc https://doc.arcgis.com/en/field-maps/faq/requirements.htm mentions 1:1 and 1:many relationships but not many:many.
I don't think many:many is implemented. I've tried as well and it never worked for me.
Best,
Andrea
DuncanKinnear
Yeah sorry Caitlin i'm not sure - I've never actually tried using a M-M relationship in AGOL.
Have you tried accessing your related records using an Arcade expression on the pop-up? i.e. https://community.esri.com/t5/arcgis-online-blog/show-related-data-or-tables-in-pop-ups-with-arcade/...
Again, I haven't actually done this with a M:M before, but it should be possible.
Cheers
Caitlin_Todd_LCOR
Hi Duncan and Andrea,
I believe Andrea is correct that it's not currently supported. I thought about going the route of using Arcade in the pop-up to show related records, but without the M:N support of a 3rd table housing the related unique IDs, it can't find which records are the related ones.
It is disappointing it's not supported at this time, but hopefully it will be soon!
Thank you both for your time and advice,
Have a great day!
Marcy_GIS
Years later and I've spent a couple days trying to fix this same problem only to find out that it is fixed with a toggle in Field Maps Designer... I've been working with an ESRI rep and everything. I sure do wish I came across this thread sooner haha.
MohamadChibli
For M:N this is a known issue in iOS. See BUG-000146019
