Rearrange Attribute Fields
1787
04-16-2021 09:18 PM
JamesMcAllister1
Is there a way to rearrange attribute fields in a hosted feature layer?
When I published my hosted feature layer for some reason all of my feature layer fields moved around. When I export the data from AGOL I need it in a specific order and I don't know how to rearrange it.
Things I've tried:
Changing the order of field using REST API
Using the hosted feature layer Visualization tab and changing the order of the attributes
JayantaPoddar
Another option would be using Configure Pop-up. Also check if the steps for changing the field order from Visualization tab has been followed correctly. FAQ: Is it possible to reorder field columns in the ArcGIS Online Map Viewer attribute table?
Think Location
JamesMcAllister1
I've tried both those things and no luck.
