raster background in AGOL
2094
06-22-2013 08:39 AM
bogdanpalade1
I am uploading some raster data as tile packages to AGOL in order to use them later for different maps. I generate them in arcgis desktop and then use the option to share as Tile Packages. I notice that after uploading to AGOL (via "add item") the .tpk and making a map service,when I try to create a map with it the image has a white background that grows as I zoom out. If I zoom out for example at a country scale, this white background would cover the entire country. This looks very bad. Do you know what might be the problem?
Thank you very much,
Bogdan
bogdanpalade1
Bogdan
I managed to solve the problem by changing the tile format from jpeg to png8
