Quick Capture - Can't use this feature layer due to an unknown error
3748
5
08-18-2020 04:55 AM
KateO_Loan1
I am trying to add a feature layer to quick capture from ArcGIS Online.
The layer is proxied from Arc GIS Server 10.5 with the appropriate security.
The credentials were stored when adding to ArcGIS online
I can use this data in Arc Collector but wanted a more simple interface.
I get the attached error when I try to add the feature layer. Can anyone help with this?#esritechnicalsupport
Tags (1)
JackBuckley
I, too, have this question. I'd love to hear a reply. Thanks in advance. Jack
JackBuckley
I'm wondering if the answer to the question is related to the number of fields and lists within fields, ie., Quick Capture can only populate X number of fields?
NathanielGaytan
I just ran into this error. Have you found a solution?
NathanielGaytan
I figured out my issue with the target hosted feature layer: I was using Custom Images for Unique Symbols.
Apparently, QuickCapture doesn't allow for buttons to be  created from custom images; once I updated symbology to symbols from AGOL style files, I was able to create the project.
mthompson
I created a hosted feature layer from scratch in our Portal on 10.7.1 and I am still getting "Can't use this feature layer due to an unknown error". It only has 4 text fields and 1 date field. I haven't set any symbology or anything on it. I also can't create a project using the templates as it gives me pretty much the same error.
