Query in ArcGIS online
5587
06-20-2012 11:09 AM
forestknutsen1
So it looks like there is no way to query content that I have uploaded in the form of a shapefile and then published as a map in ArcGIS online, e.g. find point 15.92 based on the values in the attribute table for the shapefile. Is this right? It looks like I could do a query in ArcGIS Explorer online. When open the map in ArcGIS Explorer online and I go into the Queries dialog it get, "There are no layers present in the map to define a query upon." Then when I go into the the Layer details dialog there is no filter option as explained in:
http://help.arcgis.com/en/arcgisexplorer/help/#/Filter_features/015600000059000000/
The end goal would be to have the map user be able to search the map based on a few index codes located in the attribute table of the shapefile. I have a few shapefiles in the map, all have an index field but not all of the field are tilted in the same way; however they are all strings.
Do I have to compose the map in ArcGIS Explorer online to have my content searchable? I missing something obvious?
MikeMinami
Esri Notable Contributor
Queries have limited support in Explorer Online. I believe they only can be configured against layers pointing to services. You can't query at all in ArcGIS.com map viewer.
Mike
MikeMinami
Mike
forestknutsen1
I see, thanks for the feed back. So one would have to first publish the content with ArcGIS server and then make a online map in ArcGIS Explorer online. I guess at that point one may as well make a web app with the server instead. . .
