quantity by category symbology
796
02-07-2013 02:56 PM
claudiaengel
For one of my layers I am using the quantity by category symbology from ArcGIS 10.1 desktop. I need to publish this map online, but upon analyzing I receive the message: "Layer uses an unsupported renderer" and "Layer's symbology is not supported".
How can I replicate this symbology in ArcGIS online without having to split my layer into one for each category?
MikeMinami
Esri Notable Contributor
How are you publishing your data? As a hosted feature service or a hosted tiled map service? I believe if you publish as a tiled map service it should work. Publishing as features won't work because the rendering is done by the client and web browsers and mobile devices only can draw simple symbols.
Mike
claudiaengel
Thanks, Mike, I see. Yes, I published as feature service. I am new to this, but maybe I can come up with a workaround.
Thanks again.
