Publish a map service
950
05-19-2013 05:13 PM
DavidMitchell1
I'm a newbie to this.
I'm trying to use ArcGIS Online to publish a map service generated from a feature service, itself coming from a csv file I uploaded.
I've gotten the map service set up initially, complete with valid extents.  Long Beach, California, Left: -118.26 Right: -118.06 Top: 33.89 Bottom: 33.75 - for anyone curious.
When I next click the Manage Tiles link, it comes up with a count of map tiles to be generated; looks to be too few, but what to do?  As may be, when I next click "select all scales", then hit the button [Create Tiles], a pop-up with "Invalid Extent" appears.
Generation of the tiles seems to be necessary for viewing the feature data - right?  Well, anyhow, how to get past this?
MikeMinami
Esri Notable Contributor
After searching arcgis.com for your items, I found a CSV, a hosted tile service and a hosted feature service.
You should be able to use this item directly in your web maps. You don't need to create a hosted tile service. Just use this service.
http://www.arcgis.com/home/item.html?id=1f6290ec68964c39b86dfcb0b670e841
I was also able to reproduce the invalid extent problem you saw when publishing your feature service as tiles. THis is a bug that I believe is due to the fact that your CSV only has 1 point feature in it, so the extent probably isn't set right. We'll have to investigate this.
Mike
MikeMinami
No, you don't need to generate tiles to view a feature service. You should be able to add the feature service as a layer in your map.
I'm not sure why you're getting the error, however. Perhaps you can share the URL to your feature service item.
Mike
DavidMitchell1
http://services.arcgis.com/ZL1FaY9E048zXzTf/arcgis/rest/services/CIP_Projects_TEST/MapServer
It's only got one (maybe two) point objects in it.  I may have added the second when I opened the feature service directly in a map viewer window.  Anyhow, neither seems to be visible now.
MikeMinami
Mike
DavidMitchell1
Thanks. I'll post again if I have any further questions.
