project package
960
08-23-2022 02:21 AM
AntonioEder
hey
so i want to take my arc gis pro files in a project package. but unfortunately there is always an error message because supposedly a geoprocessing tool did not work properly. so but the steps bevor have all worked..can someone help me for this problem?
DanPatterson
MVP Esteemed Contributor
remove failed tool runs from the project "history" or exclude the history from packaging
Package Project (Data Management)—ArcGIS Pro | Documentation
Similar to project toolboxes, geoprocessing history (the result information from running a geoprocessing tool) will be included in the package. Data required to process the history item will be included in the output package regardless of whether it exists in a map or scene. Any history items that are invalid (failed during processing) or where data cannot be found will cause the packaging process to stop. You must remove or fix the history item in question. History items can be excluded from a project package by unchecking the Include History Items parameter.
... sort of retired...
