Problem with unique value simbology
2686
8
11-23-2011 01:26 PM
Jose_FranciscoSánchez_Díaz
I'm making a Nature Reserve map and I have a problem with simbology.
I used unique values in several layers. I symbolized all data but I always have "other values" into legend.
Is posible to avoid this?
Thankyou!
Here is the map:
http://apps.arcgis.com/hosted/OnePane/basicviewer/index.html?appid=4541f98da882422ca58aeff292d20fd9
MikeMinami
Esri Notable Contributor
At this time, there is no way to turn this off in ArcGIS.com Map Viewer.
Mike
RupertEssinger
Esri Alum
To prevent the 'Other values' class appearing, open your web map in ArcGIS Explorer Online and do the symbolization there instead of in the ArcGIS.com map viewer. The 'Other values' class won't appear in the legend when the map is viewed in either client.
Thank you!!!! It works perfect!
JasonBarnes
Mike
Mike,
I see this post is rather old. Is there still no way to avoid getting "others" in the legend for a map in a web application?
Jason
MikeMinami
As far as I can remember, this has not changed. I assume you are seeing it.
Mike
JasonBarnes
Mike
Mike,
Yes I am seeing "others" in the legend and would like to remove it. I'm not familiar with arcgis explorer online so haven't gone the route of the workaround stated above.
Jason
MikeMinami
it's not hard to do.
When viewing your web map details (not the map itself), click the Open button and View in Explorer Online.
Mike
JasonBarnes
Mike
Worked perfectly. Thanks Mike.
