Problem Publishing Hosted Service when SSL enabled
1311
04-05-2012 06:47 AM
MaartenTromp
When SSL is enabled on ArcGIS for Organizations I can't Publish Hosted services. In my organization I am behind a proxy, maybe this influences the behaviour...
Looks like issue is related to this thread:
http://forums.arcgis.com/threads/54412-There-is-not-enough-space-in-your-online-account-to-upload-th...
People having the same issue?
Regards, Maarten Tromp
MikeMinami
Esri Notable Contributor
How are you connecting to your organization in ArcMap?
On the sign in dialog, did you click the "Manage portal connections" link and enter the name of your organization, also using "https://..." as the URL?
Mike
MaartenTromp
Hi Mike,
The "Manage portal connections" solved the problem I ran into.
Thanks for the quick response!
Regards, Maarten
MikeMinami
Just FYI for when you get an update to ArcGIS Desktop 10.1...  The Manage Portal Connections option will be moved to the ArcGIS Administrator application, the same place you set your license.
Mike
