Problem: Hosted tiled map services do not publish as expected in ArcGIS Online
3000
06-20-2017 01:14 AM
RyanGardner-Cook
I think there is something fundamental that I am missing about publishing tile packages from ArcMap 10.5. I am trying to use a custom basemap. However, I experience the incomplete publishing problem (i.e. levels 15-19 are not fully published) highlighted in this technical article: Problem: Hosted tiled map services do not publish as expected in ArcGIS Online
I made sure that ArcMap uses the extent of data in all layers, so it shouldn't be clipped.
I even try the publish tile option in the item details of the hosted tile layer, but it never actually changes.
What am I missing? Do I need to do something with "Generate Tile Cache" while in ArcMap?
Thank you!
JayantaPoddar
I hope you haven't burnt all the credits. In case if you don't have ArcGIS Server, you should use the following method to publish tiled services to ArcGIS Online
https://community.esri.com/docs/DOC-2996-publish-a-tiled-service-to-arcgis-online-wo-arcgis-for-serv...
Think Location
JayantaPoddar
Think Location
RyanGardner-Cook
This looks like just what I need. Thank you! Going to give it a try.
RyanGardner-Cook
That did it! Thanks for pointing this document out. I wish Esri's technical article was as detailed.
JayantaPoddar
All credits to the author of the article, jskinner-esristaff‌
Think Location
