Print output does not contain all data visible on map
608
11-10-2025 06:00 AM
KatyAppleton1
When using Print from Map Viewer to create a layout, sometimes the output does not match the map.
Example: Population, when symbolised by dot density - dots do not show at certain scales. (Shows fine with original polygon symbology; dots show at larger scales, but arguably the value of point density is in the overview!)
I (and my students) expected the output to be a snapshot of the data, as seen. Is this expected behaviour?
(This was originally posted in another thread alongside what I thought was a similar issue; that has now been solved but this one remains.)
ZaraMatheson
Hello! Thanks for reporting. I'm able to reproduce this issue and it looks like a bug. The team is investigating.
