Preventing symbols from different layers from interfering with each other in AGOL
1181
04-05-2013 07:37 AM
SteveCline
I am tackling a project that contains several new elements for me since I am a high school social studies teacher and not a full-time GIS professional.
For this particular project I am trying to show the various US interventions during the Cold War around the world. I have created individual points for each intervention. These points are in a shapefile that contains a list of 49 different interventions. The fields include the country of the intervention, the year, a short description and whether or not a certain type of action occurred.
Example: Guatemala, 1954, (description) and the following values for the six types of action possible: Command=1, Troops=0, Bombing=1, Naval=0, Nuke=1, Jets=0. What this means is that in 1954 we used Command Operations, Bombing and Nuclear Threats to intervene in Guatemalan affairs. On this particular point then I would like to see the three distinct symbols for those types of action. Currently I can achieve this by creating 6 layers but the symbols are all stacked on top of each other.
Here is the link to my first attempt at a map service: http://bit.ly/10EHUAU
This has all been done in Desktop 10.1 Advanced. I plan to create a feature service on our AGOL account once I have solved this problem.
Thanks for any advice.
RobertBorchert
Honored Contributor
Have you tried adjusting the visibility scale.  You can adjust it so they don't turn on until you get to within a set scale.  Unfortunately not a lot of great options in ArcGIS online for displaying as you would on desktop.
RobertWeise
Hi Steve,
What I have done in the past with a situation like that was the following:
- create a graphic box that has the six items displayed as symbols, as part of that graphic (think of a small table with two columns and three rows, having 6 boxes each representing one of your six features)
- once you have this basic graphic, create copies of it for all combinations, highighting the options in the 6 boxes that have a number rather than a zero
- create a column in your attribute table that brings the 6 categories together (ie 100110)
- symbolize this new column with your newly created graphics
this would show every point with the same base graphic, but highlighting the options / features that apply.
Let me know if this makes sense, or I can see if I can dig up a visual example.
RJ
SteveCline
Hi Steve,
RJ
I will give this a try and let you know if I need an example.  I think I know what you mean.  Thanks.
