We have a sharepoint list that we'd like to replicate in the AGOL via power automate.
The hurdle for us how do we set up the "Create a record in a feature layer" connector. We have tried passing the "geometry" parameter multiple ways. We have tried -
x,y
AND
"geometry": {
"x": 1436052.3270733608,
"y": 5002615.309330223,
"spatialReference": {
"wkid": 2193,
"latestWkid": 2193
The flow runs fine and creates the feature but with no geometry.
Anyone used this connector before, that might have an idea?
Also there is surprisingly low information on these connectors and the format of the inputs they expect.
A quick glance at your json object looks like you have 2 opening brackets "{" and only 1 closing bracket "}".
Id try this format:
"wkid": 2193,
"latestWkid": 2193
More details regarding Geometry objects can be found in the Developer Documentation at here
Id try this format:
"wkid": 2193,
"latestWkid": 2193
Thanks @alex_mapintel , I copied the code incorrectly. It had the brackets.
It also didn't like the keyword "geometry" in the code.
What worked for us was the below -
"wkid": 2193
OR
"x": 170.8504403060537,
"y": -45.360211429819564,
"wkid": 4326
Thanks again.
Thanks for this solution!
Also, in case anyone else is having trouble with this, just copy/paste the code directly into the "Geometry" bar--not the f(x) bar in the Expression window that appears when you click in the "Geometry" bar.
