Portal inside firewall with Active Directory, ArcGIS
4029
01-24-2014 07:49 AM
DanielMcAlister
Hi, I'm trying to architecture a Portal for ArcGIS setup within a company firewall - integrating with Active Directory, mostly but not exclusively to avail of Esri maps for sharepoint integration. I'd like to place the spatial data in arcgis server services on the amazon cloud, could these services support portal inside the firewall and at the same time be accessed by non portal, regular web apps hosted on the amazon cloud? Many thanks for any thoughts. Dan.
MiguelMorgado
Hi Daniel,
Are you asking if you can access the map service located in the Amazon EC2 AGS server from your Portal?
If this is the question, then yes you can. The external map services will act as any ESRI basemap. However for that work you need to allow the URL to pass through your firewall.
For use AD authentication on your map services you will need to setup a AD on your Amazon server and configure the connection between your company and this server (e.g.: site to site VPN).
