Popup is automatic disabled
522
01-15-2019 05:51 AM
EricS
I have a web map that I am the owner of and in my map the popups are turned on and work fine.  In portal other members are showing that their popup is turned off.  They turn the popup on but when they close and come back the popup is turned off.  Where can I go to fix this issue?  Does it matter if the member in portal is a user??  Its 10.4 environment
