Pop-ups not working in Map Viewer
39041
68
04-20-2023 09:18 AM
Triflight
I have a web map created in ArcGIS Online where the pop-ups for one of the layers does not work. When clicked on, instead of the pop-up popping up nothing happens. The other layers on the map have their pop-ups working correctly.
The problem layer in question has pop-ups turned on and they are custom configured to display a select number of fields & it uses an Arcade expression for the title.
When using the map in the Field Maps mobile app and selecting a feature from this layer, the custom configured pop-up works and can be viewed. When viewing the map in Map Viewer Classic, the custom configured pop-up works and can be viewed. When viewing the map in Experience Builder using the map widget, the issue persists and the pop-ups do not work.
I am truly unsure why Map Viewer refuses to display pop-ups for this single layer, any assistance would be greatly appreciated.
dhochhal
Update to this post!
I cleared the browser cache, cookies, etc. and popups as well as attachment links started working in both map viewers! Pretty simple fix, but I stand by the statement about slowing up the version changes until everything works, or just more quality checking maybe.
MK13
@RussRoberts  @EmilyGeo @bbollin  Any idea on how to get pop-ups to work in map viewer for polygon layers published with a transparent fill and dashed outline? Currently pop-ups only work when one clicks on the outline.
bbollin
@MK13 Can you provide more information? I can click a transparent /dashed outline polygon in the middle and the popup opens fine.
MK13
@bbollin Interesting! As you can see in my image below, the pop-up only opens when I click on the outline of the polygon and doesn't open when I click inside the polygon. May I ask if the dashed symbology that you have was published from Pro or set up in map viewer?
bbollin
@MK13  Ok I see, it sounds like this is a known issue when publishing from pro. I would try recreating the symbology in Map Viewer, should have the desired effect.
MK13
@bbollin when I attempted to re-create it in map viewer, there was no option to create a dashed outline for the polygon. All I could find was the solid stroke.
bbollin
@MK13  You will find it under "outline" for the pattern
MK13
@bbollin unfortunately I don't have that option. Please see below. I am utilising Map Viewer in ArcGIS Online.
JoeBryant1
This fixed the issue for me, too! I republished twice trying to clear the bug with no luck. Thanks for posting @AndrewRoberts1 !
It would be great if @RussRoberts could mark @AndrewRoberts1 's response as the correct solution so it was easier to find.
