Pop-up: Link to URL with Link text; if empty return text No As-Built Document text
389
04-02-2026 07:07 AM
GeoWorld13
Hello - I would like to create a dynamic pop-up that links out to an As-Built document related to a feature. However, some features do not have any As-Builts and have empty values in the data. If that is the case, I want the pop-up to read: There is no As-Built Plan for this project.
What I have so far is an attribute expression:
if (IsEmpty($feature.Orignal_Project_PDF)) {
    return "There is no As-Built Plan for this project.";
} else {
    return '<a href="' + $feature.Orignal_Project_PDF + '" target="_blank">Link</a>';
Pop-up HTML:
<p>
<strong>📄 As-Built Plans:</strong><br>
{expression/expr4}
</p>
How ever my pop-up looks like this:
See anything I am doing wrong?
@jcarlson
@KenBuja
@RussRoberts
Neal_t_k
MVP Regular Contributor
@GeoWorld13
I just revisted and think I got it to work, instead of an expression and a text popup, just add an Arcade item and do all of it there:
add this code:
var nolink = "There is no As-Built Plan for this project."
var url1 = $feature.Orignal_Project_PDF
var base = ""
    var base =  nolink;
} else {
    var base = '<a href='+url1+' target="_blank">Link</a>';
return {
	type : 'text',
	text : "<p><strong>As-Built Plans:</strong><br>"+base+"</p>"
Neal_t_k
This gets you closer, however it formats the static text as a link as well...
The expression:
else {
    return  $feature.Orignal_Project_PDF;
Then to add that in the popup add text and insert your expression as a link and put in your expression name.
HTML:
<p>
<a href="{expression/expr0}">{expression/expr0}</a>
</p>
Reference:  Solved: Re: Arcade add URL to pop-up - Esri Community
Neal_t_k
@GeoWorld13
add this code:
var base = ""
    var base =  nolink;
} else {
return {
	type : 'text',
GeoWorld13
@Neal_t_k this worked, thanks!
