pop-up attribute configuration
1472
01-18-2024 05:54 AM
RamonWilliams
I have a feature service that I have created that has 75 layers and I am configuring the pops to view two of the fields numbers as 8 digits after the decimal point.  I also have 3300 views that are created from the service, all the views do not update with the two fields that I have chosen the 8 decimals to show. without doing it manually changing every view.    Is there a way to update them views programmatically with the updated fields showing the 8 digits after the decimal?
RobinDiSalvo1
Hi Ramon,
I saw your post and not that I can help solve your issue, but I am having a similar issue you might be able to help me with.  I too, created a pop-up attribute and noticed my percentages were in decimals.  Instead of the 5-Year % Growth showing 31% it shows 0.31.  I am not savvy on creating attribute expressions.  Do you know how I can fix this?
Thanks in advance,
Robin
RobinDiSalvo1
There's a way to create the percentage using the attribute expression, I am not savvy enough to figure it out yet.  When I do, I'll let you know.
