polygon to point preserve attachments
3836
11
07-06-2017 11:14 AM
by Anonymous User
Not applicable
Hi all,
I am trying to preserve attachments when i convert feature to point in arcgis desktop in order to have users collect in the field. Is that possible?
Alex
Tags (1)
by Anonymous User
Not applicable
Shantonu,
- The attachments are added via the GlobalID/rel-globalid not OBJECTID/rel-objectid. GlobalIDs were used here because I need to be collecting data via collector.
- The only common ID fields between the point FC and the attachment attribute table are these two: GlobalID/rel-globalid. I don't have any other join fields.
- Least importantly  but yet still an issue, The "Add attachments" tool requires that you provide a "Match path field" which the closest "match" field in my table would be "ATT_NAME" and this is not a  a path field.
by Anonymous User
Not applicable
I found a way to preserve attachments when converting from polygons to points:
1) FC poly ==> create GUID field
2) Attachment Table ==> Create GUID field
3) Calculate each GUIDs for eachtable (polygons and attachments) with the GlobalIDs(polygons) and rel-globalids(attachments) values
4) Create a new text field in the Attachment table called Path (length 100 or more)
5) Calculate the path field like this:
6) Export attachments using this tool How To: Batch export attachments from a feature class to your local machine "C:\atch" for me.
7) Use Feature To Point—Help | ArcGIS Desktop tool to convert poly to points
😎 Add GlobalIDs to the new point FC Add Global IDs—Help | ArcGIS for Desktop
9) Enable Attachments to the new point FC Enabling attachments—ArcGIS Help | ArcGIS for Desktop
10)Use theAdd Attachments—Data Management toolbox | ArcGIS Desktop tool to add the pictures back
Input Join Field : GUID of your point feature class
Match join field: GUID  of your attachment table
Match Path: field that stores the path to the pics on your PC
11) Done.
