Please help overcome this Obstacle
921
08-07-2020 10:35 PM
BaselAmmane
I am trying to finish this tutorial but I am stuck at the part where I have to use the derive new location tool by inputting three query expressions. Two of them involve using "where". For some reason the "add" button is dimmed and I can't move forward.
Here is the link: Analyze Credit Card Fraud | Learn ArcGIS
by Anonymous User
Not applicable
Crossposting this to the Learn ArcGIS‌ space to see if someone there has run across it.
HeatherSmith
Esri Alum
Hi Basel,
Thank you for identifying this problem. A fix is in the works and we will  be updating the lesson as well. In the meantime, you can get around the issue by following these steps before the steps in the Derive new locations section of the lesson.
1. In the Content pane, click on the ellipsis beside the gastransactions layer and choose Save Layer
2. Click the elipses again and click Show Item Details.
3. On the Item Details page, click Publish.
 4. Return to your map. Click Add and Search for Layers. Add the new version of the Gas Transactions layer that you just published.
5. Continue on with step 1 in Derive new locations
Now that the layer is published as a hosted service, the Derive New Locations expressions should work without issue.
