perform visibility analysis
1703
10-23-2020 04:08 PM
ArpitShah
The tutorial involves loading 3D layer of Philadelphia from ArcGIS online. While doing so, a username password is requested. I have a 21 day trial and insert that username and password but it says that it is incorrect.. why is it so?
Tags (1)
ArpitShah
by Anonymous User
Not applicable
Hi Arpit, if you browse to https://www.arcgis.com/ and select Sign in from the upper right hand corner, you are presented with a sign-in dialog that includes forgot username / forgot password options.
Hope this helps,
-Peter
ArpitShah
Thank you Peter, I was able to get support from LearnArcGIS team for this. It wasn't about wrong username password combination - the layer is no longer available and hence I couldn't access it unfortunately. The team said that they will try to change the course content in the future - no solutions available for the time being...
