Parcel Viewer web app has decreased functionality at latest release
1316
08-07-2013 08:28 AM
TiffanyPuett
Hello all,
I just wanted to put a bug out there (somehow only has a medium severity level) to try to get the issue resolved as quickly as possible. [NIM093387] It is also considered and enhancement request. How is asking for current functionality to exist in a newer product considered an enhancement?
Apparently the developers were trying to enhance the identify window and created a much larger problem in my opinion.
With the recent upgrade to AGOL, I have discovered a major difference in the identify window particularly with respect to paging through the attributes of overlapping features. I have submitted an incident to tech support.
Problem: Attributes of only 1 feature service are displayed and the feature is not highlighted. No paging is available to user whenever said feature overlaps another or user clicks edge b/t 2 features. (NewParcelVwr.jpg)
Here I've used the exact same data in the OLD viewer and notice that the paging functionality is there and that the identity window is consistent with other web applications (black title bar, maximize option, paging). Also note the highlighted feature. (OldParcelVwr.jpg)
The upgraded solution is no longer valid for it's intended purpose. Users are not able to determine the attributed feature as well the attributes of overlapping features.
MikeTschudi
Esri Alum
Hi Tiffany,
We aimed for a streamlined popup that would be more effective across browsers and platforms, but had underestimated the importance of paging through overlapping features. We changed the template back to the earlier popup and the change will be part of the next AGOL release. No change will be necessary to your web apps.
If you're hosting the app on your own server, or want to host it on your server to get the change sooner, you can get the modified template from the Esri GitHub site.
Regards,
Mike
