packaging succeeded but publishing failed
1965
09-12-2019 02:53 AM
PriyaAggarwal1
I am having trouble in publishing a hosted feature service from ArcMap 10.2 to ArcGIS Portal. When I attempt to publish, I suddenly started getting this error message. Previously it was working fine.
packaging succeeded but publishing failed failed to execute upload service definition
Log report on server. The warning and severe cases on 2019-09-12 at 09:41 are related to above publishing error.
Log File after error in ArcMap
I have Tested all below methods and still not got any solution:
Restart Publishing tool on server manager
validate Datastore  – Its working perfectly fine
Publish mxd with different names
Tried Publishing layer, feature class, .shp
Tried Publishing Zip file of shp, directly on portal by using add item.
Windows authentication enable on IIS for server web adaptor
Restart services on task manager
Server drives have sufficient space
Has anyone run into this issue and how can I resolve it?
Thank you for any help or pointers in the right direction!
HemantAngarkar1
Are you getting error for any layer or a particular layer? Also if you can share the error message and error number from GP results windows, it would be helpful.
HemantAngarkar1
PriyaAggarwal1
Thanks for your reply..
I have tried different layers even from different systems but its not working.
GP Result Window
HemantAngarkar1
Generic error message in GP Results window, that's a tricky one! Did you try steps given in article that I shared in my second comment?
