Overwrite web layer from ArcGIS Pro stuck on "Uploading Service Definition"
9524
22
03-21-2024 06:17 AM
JulianMcCoy
I'm trying to overwrite one of my hosted feature layers with a layer from ArcGIS Pro, as I've done many times in the past. It gets stuck on "Uploading Service Definition".
Version is 3.0 (I know I should update it, but it was able to do this yesterday. I have to call IT every time I update and it's a whole thing, so I hang on to the versions that work for me)
I have a Standard license and I'm signed in everywhere.
JLyon
anyone have issues now with a failure to publish layer, overwriting existing layer, and in doing so deletes the layer in your content? Has now happened 2x in the last 24 hrs.
HeatherWidlund
Yes, this happened to me 3/26/24. It was with a manual overwrite from Pro.
Data point: My overnight overwrite scripts still seem to be working.
Laura
by MVP Regular Contributor
I have experienced this and am once again today. I have to restore it from deleted and keep trying.
Tim_Rodaway
Has anyone managed to get to the bottom of this? We've had it occuring intermittently for a good few months now. We're overwriting ~20 layers nightly, and often finding it randomly hangs on one of the layers (different ones). We're using a Python script and it's the overwrite function that it fails on specifically. I've seen it happen once in ArcGIS Pro too, but didn't have the diagnostic monitor open for it.
I was thinking we were alone with it, so likely an internal network issue, so was putting off logging a report, but it sounds like it's something on Esri's end given others are facing it too.
KristyCline
Just adding myself as another Esri user experiencing these issues with an automated process that was working fine for years, but now hangs on 'Uploading Service Definition'. The layer it gets hung up on doesn't seem to be consistent.
DRicotta
Adding myself, same problem.
AltoonaWater
Popping in to this old thread, I am now having this issue 5/20/2026 after updating to Pro 3.7
FourquetDanielVDOT
Same problem, also 5/20/26.  Maybe a server problem?
HeatherWidlund
I had 2 scripts that overwrite services fail and 2 succeed so not sure. When I reran manually, 1 failed again. I logged into Pro, closed it again and then the 2 that failed succeeded. Also updated to 3.7 yesterday.
KathleenBallew
My coworker and I are both having this same issue today. Have tried publishing several different layers and they all get stuck.
