Overwrite and update Vector Tiles using Geoprocessing
1362
01-09-2023 07:30 AM
Labels (2)
LyonMNGIS
I would like to update vector tiles using Geo processing tools.  I was advised to try the replace web layer tool.  It does not work.
Basic workflow to create the initial vector tile layer in AGOL:
  • Author a map in ArcGIS Pro.
  • Open the Publish Web Layer tool within the share tab.
  • Share as a vector tile layer
  • Result:  The initial vector tile layer is published in AGOL
Basic Workflow to try to update the vector tiles:
  • Open ArcGIS Pro
  • Open the Replace Web Layer tool in the Share menu
  • Select the target layer in ArcGIS Online
  • Navigate to the update layer (The Map within my ArcGIS Project)
  • Result:  Fail.  I cannot select the map in the Update Layer tool.
Another Workflow to try to update the vector tiles:
  • Open ArcGIS Pro
  • Open the Create Vector Tile Package GeoProcessing Tool
  • Create a vector tile package (vtpk) on my local drive.
    • The vtpk file can be overwritten on my local drive, but not within AGOL
  • Open the Replace Web Layer tool in the Share menu.
  • Navigate to the Update Layer (The Vector Tile Package that was saved to disk)
  • Result:  Fail.  I cannot select the Vector Tile Package..
Please let me know if there is a way to update vector tiles within ArcGIS Online.
Thank You
