I would like to update vector tiles using Geo processing tools. I was advised to try the replace web layer tool. It does not work.
Basic workflow to create the initial vector tile layer in AGOL:
- Author a map in ArcGIS Pro.
- Open the Publish Web Layer tool within the share tab.
- Share as a vector tile layer
- Result: The initial vector tile layer is published in AGOL
Basic Workflow to try to update the vector tiles:
- Open ArcGIS Pro
- Open the Replace Web Layer tool in the Share menu
- Select the target layer in ArcGIS Online
- Navigate to the update layer (The Map within my ArcGIS Project)
- Result: Fail. I cannot select the map in the Update Layer tool.
Another Workflow to try to update the vector tiles:
- Open ArcGIS Pro
- Open the Create Vector Tile Package GeoProcessing Tool
- Create a vector tile package (vtpk) on my local drive.
- The vtpk file can be overwritten on my local drive, but not within AGOL
- Open the Replace Web Layer tool in the Share menu.
- Navigate to the Update Layer (The Vector Tile Package that was saved to disk)
- Result: Fail. I cannot select the Vector Tile Package..
Please let me know if there is a way to update vector tiles within ArcGIS Online.
Thank You
