Opening attachments via attribute table in new Map Viewer
1785
12-29-2022 01:58 PM
tacostar
In the Classic Map Viewer, I could open attachments from the attribute table. In the new Map Viewer, there is no hyperlink to an attachment in the attribute table - there is only a "1". Does anyone know if it's possible to open attachments via the attribute table like you used to in the Classic Map Viewer?
JonEmch
Hello there @tacostar,
   Thank you for reaching out. While researching this question, I happened to find this tech article that may be helpful to you: How To: Show attachments from a related table/layer in the pop-ups in a web map.
   This is specific to related tables, are you using these in your workflow?
Keep on keeping on!
RhettZufelt
MVP Notable Contributor
You can do that in the Data tab of the item details page.
R_
ZacharyUhlmann1
@RhettZufelt has a nice option, but it is not interactive with the webmap open.  @JonEmch is referring to popups.  What the OP wants and misses from Map Viewer (me too!) is the ability to open the popup from a link directly in the attribute table in the webmap itself.  It's time-consuming to interactively navigate through a field collection map with attachments without that previously-available functionality.
