One to many features with forms
5265
10
10-31-2023 08:17 AM
KristalWalsh
Currently customer info (point hosted feature layer) is entered, property boundaries created (polygon hosted FL) and the customer number (an auto-sequence id) is pulled by a spatial intersect in AGO.  These two geometries are both related to the same propertyinfo table but was changed from a feature:feature relationship because this relationship type will not work in forms per this blog https://www.esri.com/arcgis-blog/products/arcgis-online/mapping/introducing-related-record-editing-i...
My set up works okay for the first customer but I need to be able to maintain/ "pull" that customer id for subsequent properties that may be added for the same person? Creating additional customer points would duplicate customers and the auto-sequence arcade script renders the field not editable.  I would like for the customer info to be found via search of the map, then a new property feature added.  Without a feature-to-feature relationship, I'm not sure how to do this.  This portion of the workflow does not have to be completed in Field Maps but needs to be user friendly, hence the forms. I've attached my scratchpad ERD. Thank you so much for any assistance!!
Kristal Walsh, Florida Fish and Wildlife
Office of Conservation Planning
JuanManuelCruzHerrera
esto si que es una gran noticia y a mi me soluciona problemas para el futuro, ahora tengo en Server el 11.1 pero puedo ir pensando trabajos así para cuando pueda actualizar porque deseo tener el dato controlado por una tabla relacionada más que habilitar el archivado y los marcadores o el versionado en rama ya que para recuperar los datos no es tan directo y esto si que el es. y puedes tener el histórico de los datos sobre la marcha para por ejemplo un tema de emergencias
