Not all features from a map service are displaying
2723
07-19-2012 11:34 AM
AndrewEdmonds
I have created two ArcGIS Online webmaps using data from a WMS my organization publishes.
http://www.arcgis.com/explorer/?open=18e89fb2b78144fbb31087e1a56f77f5
http://www.arcgis.com/explorer/?open=5085e0e78e5b4928a7bc57019b9a1879
The former draws from the WMS and correctly displays all features.  The latter draws from the specific layers (ie, http://gis.ncdcr.gov/ArcGIS/rest/services/NC_National_Register_Mobile/MapServer/0) and does NOT display all features.
I thought this problem might be related to the 1000 feature maximum import to shapefiles described in this thread, but the solution listed there is to create a map service.
So, why does the second webmap limit my displayed features?  The only difference I can see is how the data are brought in.
MikeMinami
Esri Notable Contributor
In one web map, you've added the individual layers of an ArcGIS Server map service to the web map. By doing so, you are effectively accessing the layers like a feature service. The web map sends a query to the service to retrieve the geometry and attributes of the features and the client application draws them. So it works identically to how a feature service works and is limited to the number of features the client can draw.
In your other web map, you've added the entire map service. In this case, the web map sends a request to the service and the service draws all the layers and creates an image representation that the client then displays, sometimes transparently.
Make sense?
Mike
MikeMinami
Make sense?
Mike
AndrewEdmonds
Thanks, that makes sense.
