Newly Created Map Service Not Displaying
1914
12-08-2010 07:39 AM
MapManOregon
I connect to my Map Services, http://services.medfordmaps.org/ArcGIS1/rest/services, and get 16 results.  I then create a new Map Service using ArcCatalog, 'Code_Enforcement', and try to get the results box in arcgis.com to display this newly created map service.
I does not display, even when I re-click the option to add 'A GIS Server' .  I close the Add box and try to trick ArcGIS into refreshing, but it doesn't.
How do I get a newly created map service to display in the Results list?
Thanks.
keith
MikeMinami
Esri Notable Contributor
When I connect to your GIS Server I can see the Code Enforcement service and am getting 18 results returned. What I suspect is that the list is getting cached by the browser. Try clearing your browser cache and see if that helps.
Mike
MapManOregon
You are right.  It was a browser caching issue.  Thanks.
