I am finding that new features (geometry) that I'm trying to add to my map in AGOL disappears as soon as I finish drawing it. I was able to add features the other day but could not edit them. I am new to AGOL and cannot figure out what I'm missing. This map and data is mine, I am the crator and administrator.
Any thoughts or help would be greatly appreciated.
I've
moved your post into the Web GIS space. You will get a much better answer here as the GeoNet Help is intended for community help and feedback. I have also added in a few additional tags. You can see more
on the community structure, and what topics are under each space from the
following documents:
ArcGIS Discussion Forums Migration Strategy
Thanks!
Don
Hello Leah,
Are you using ArcGIS Server Feature Service in ArcGIS.com webmap or is it an ArcGIS.com hosted feature service?
A good test would be to consume your service in any other client you are familiar with.. For example a Flexviewer application. If its an ArcGIS Server FS then it might be related to some sort of a permission issue over the Database. In that scenario you might want to try and publish another feature class as a FS service on ArcGIS Server and then try and edit it through ArcGIS.com.
