New Map Viewer Repeat Labels
8402
12
05-11-2021 01:56 PM
James_Norquest
I may be missing something simple here but I have this issue in the new map viewer as well as in experience builder. I am getting repeat labels that make these new products basically unusable. Has anyone else had this issue? It works fine in map viewer classic and webapp builder.
Thanks!
SMH-Rio
I believe there is a bug with this option when the label uses Arcade + line break (with TextFormatting.NewLine or \n).
Repeat settings are completely ignored when the arcade uses a line break. When I remove the line break (but keep everything else Arcade), everything works fine.
RussRoberts
Esri Notable Contributor
Thanks for reporting. This looks to be localized to the Text Newline formatting and is reproducible in other versions of the JSAPI so its not related to the recent release. You can log a ticket with support if you would like a ticket to track.
EwaKlinkvort1
We have the same problem with not visible option: Repeat Label in Map Viewer.
Also Portal/Enterprice solution.
Do you have some suggestions for workaround?
