Need Help with selecting parcels for damage assessment
2154
01-28-2014 01:06 PM
by Anonymous User
Not applicable
Original User: stevec
All,
Thank you in advance for your assistance. What I am looking for is how to set the behaviour of selecting polygon/parcels in ArcGIS online? When in ArcMap and a polygon is selected for editing it shows in the default blue, is there a way in AGO of doing this? When I select a polygon in AGO the selection in the edit mode shows up faintly and does not have a color around the poly to show it's active for editing, it appears as a vertices edit? I need to find out if the selection properties can be changed to show a color? I hope I am being clear enough. This is for a damage assessment application that I am working on. Thanks again for any help,
Regards,
Steve
