Need help creating a pop-up chart pulling data from related table
1004
02-03-2025 07:48 PM
BNRiverkeeper
Please help, I've been trying for hours as someone with minimal arcade experience. Here is the code I have:
// Access related table
var portal = Portal("https://www.arcgis.com")
var relatedTable = FeatureSetByPortalItem(portal,
    "558cb226d1cd403c9e9bfc5dacd8ea67", 1, ['station_id', 'record_date', 'E__coli'])
var station_id = Text($feature.station_id)
var relatedData = Filter(relatedTable, "station_id = @station_id")
// If no related records exist, return null
if (Count(relatedData) == 0) {
    return null
// Sort records by date (ascending)
var sortedData = OrderBy(relatedData, 'record_date ASC')
// Prepare lists for charting
var dates = []
var ecoliValues = []
for (var f in sortedData) {
    // Convert date and E. coli values to the correct format
    var formattedDate = Text(Date(f.record_date), 'MM/DD/YYYY')
    var ecoliValue = Number(f.E__coli)
    if (!IsEmpty(formattedDate) && !IsEmpty(ecoliValue)) {
        Push(dates, formattedDate)
        Push(ecoliValues, ecoliValue)
// Return correctly formatted data for ArcGIS Online Charts
return {
    "labels": dates,  // X-axis (dates)
    "datasets": [
            "label": "E. Coli Levels",
            "data": ecoliValues  // Y-axis (E. coli values)
I just need the chart to show E coli counts on the Y, and date on the X. The data is pulling correctly when populating the field, and it shows all related records in the pop-up table. As the code is now, the chart populates blank.
timcneil
Hi @BNRiverkeeper ,
Are you authoring this arcade expression as an attribute expression?
In this scenario it seems like you could benefit from using an Arcade content element in your pop-up. With a content element you can construct the whole chart and return it in your pop-up in a single expression.
These blogs are a great introduction (with some examples as well). I would start with Part 1 here for context, but Part 2 provides an example using a chart that at a glance seems very similar to your use case.
KenBuja
This shows the chart with your values using an Arcade element
    return null
var dates = []
var ecoliValues = {}
//var chartColors = []  //use this to have a monocolor chart
        //Push(ecoliValues, ecoliValue)
        ecoliValues[formattedDate] = ecoliValue
//        Push(chartColors, [6,47,120])
return {
    type: 'media',
    title : 'Events per Decade',
    description : 'Chart showing total events per decade',
    attributes : ecoliValues,
    mediaInfos: [{
        type : 'columnchart', //linechart | barchart | piechart | columnchart
        altText : 'bar chart showing events per decade', //altText will be read by screen readers
        value : {
          fields: dates,
//          colors: chartColors
