Multiple IF Statements from different fields
2257
07-05-2022 02:54 PM
David-Semitekol
Hello, I'm trying to write 1 arcade expression.  In my table I have a field for Sunday; Monday; Tuesday; etc.  The data is either a 1 if a work crew is at that location on that day or a 0 if they are not.
I want my expression to list the days of the week they are at each location but I'm only able to return the first instance with my formulas.
I tried and IF and Else IF statement
if($feature["USER_SUNDAY"] == 1)
{return " Su "}
else if($feature["USER_MONDAY"] == 1)
{return " M "}
else if($feature["USER_TUESDAY"] == 1)
{return " Tu "}
else if($feature["USER_WEDNESDAY"] == 1)
{return " W "}
else if($feature["USER_THURSDAY"] == 1)
{return " Th "}
else if($feature["USER_FRIDAY"] == 1)
{return " F "}
else if($feature["USER_SATURDAY"] == 1)
{return " Sa "}
And also tried a nested statement:
iif($feature["USER_SUNDAY"] == 1,'Su',
iif($feature["USER_MONDAY"] == 1,'M',
iif($feature["USER_TUESDAY"] == 1,'Tu',
iif($feature["USER_WEDNESDAY"] == 1,'W',
iif($feature["USER_THURSDAY"] == 1,'Th',
iif($feature["USER_FRIDAY"] == 1,'F',
iif($feature["USER_SATURDAY"] == 1,'Sa',NONE)))))))
I even tried replacing IIF with When but achieved the same result.  The formulas only return the first day a crew is at a location and won't combine the days if they are there more than once in the PopUp.
Is this possible or do I need to create an expression for each day of the week and then add it to my PopUp?
Thanks!
JohannesLindner
MVP Alum
When you return from a function (or an Arcade expression in this case), the code stops executing there. Everything after the first executed return statement gets skipped. That's why your first example didn't work.
It's also why your second example didn't work, because it can be rewritten like this:
if(condition1){
    return "Su"
} else {
    if(condition2) {
        return "Mo"
    } else {
        if(condition3) {
            return "Tu"
        } else {
To do what you want:
  • evaluate an if statement for each condition
  • either build up a return string as you go along or store each string and concatenate at the end
// array to store the strings
var open_days = []
// evaluate each day, add open days to the array
if($feature.USER_SUNDAY == 1) { Push(open_days, "Su") }
if($feature.USER_MONDAY == 1) { Push(open_days, "M") }
if($feature.USER_TUESDAY == 1) { Push(open_days, "Tu") }
if($feature.USER_WEDNESDAY == 1) { Push(open_days, "W") }
if($feature.USER_THURSDAY == 1) { Push(open_days, "Th") }
if($feature.USER_FRIDAY == 1) { Push(open_days, "F") }
if($feature.USER_SATURDAY == 1) { Push(open_days, "Sa") }
// concatenate the strings and return
return Concatenate(open_days, ", ")
Have a great day!
Johannes
JohannesLindner
MVP Alum
if(condition1){
    return "Su"
} else {
    if(condition2) {
        return "Mo"
    } else {
        if(condition3) {
            return "Tu"
        } else {
var open_days = []
Have a great day!
Johannes
David-Semitekol
Thanks Johannes, your solution code worked perfectly.  Just to make sure I learned and not just copied:
You assign a variable, in this case it is open_days and the = [] allows you to add to it later in the formula?
The Push command takes the output from the If statement and adds it to the variable.
At the end you are Returning the values from the If statements and adding a comma to the output for readability.
This was awesome, thank you again!
