Multiple Fields Related to a Single Table in AGOL
208
a week ago
LukePanther
I am in the testing stages for a potential project and want to use related tables in AGOL pretty aggressively. My goal is to save on having to have a bunch of fields for contact information for contractors by using related tables. What I have right now is 5 contractor fields in the parent table for users to enter in a contractor name for a plumbing, electric, and general contractors that will then be the key to relating to a singular contractor table. In that child table, data for all contractors will be stored. The Contractor name is the relation key that I used to related each of my 5 contractor fields to the contractor table. I created these relationships in ArcGIS Pro and published to AGOL. When I make a pop-up for the parent feature to the user can see the related item for each field AGOL sometimes grabs one relation and put in the pop-up for all other relations. You can see that is the pop-up screenshot below. AGOL returns the wrong item for different relationships. This is a problem like 80% of the time, the other 20% it works as it should and returns the actual item that is related. So long story short I have 5 fields in a parent feature class that are all related to a singular field and I have problems with pop-ups returning wrong items. Is there a fix to this or this a true limitation?
KVNSCK
by Esri Contributor
Hi Luke!
I made a dataset, similar to yours, with five fields in a feature layer related to a single field within a table. I tested things out a few times, and I was always able to have my pop ups return the correct information. Getting this to work should be possible!
Can you to confirm that each of your related record pop ups is configured to display the correct relationship? I've attached a screenshot of where to find this information. You should have five relationships there, one for every contractor type.
