MULTIPLE DOCUMENTS IN A POPUP
2209
06-09-2020 01:02 AM
thainamota
Hi everyone
please, i'm newbie in arcgis online.
I'd like to know if there's an alternative to viewing multiple documents in the popup? It's means, for example, when the popup appears I want to see many documents with single link. Also, is there a way to call the url without having to add a new column in the shape everytime that I have a new document about the feature(if i have 50 pdf[urls] for the same feature I must to create 50 column)?
thanks so much!
Thaina
popup info‌ arcgis online popups‌ multiple document link‌ linking tabs customize group url #url
Katie_Clark
MVP Regular Contributor
Is it possible you could just enable attachments on the layer and attach the PDF's that way? Or is there another reason you want the links to the documents as an attribute?
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Katie_Clark
Best,
Katie
thainamota
ok, maybe i'm little confused!
as i  understood, it  is necessary to have a url documents as an attribute to active the link in pop up. (its that why i thought to create one column for each url)
 I have to upload in AGOL a geodatabase with a relate or join active to  enable attachments, it's correct?
Thanks Katherine
Katie_Clark
To enable attachments on a hosted feature layer, all you have to do is click "enable attachments" on the item details page.
Note that there is a 10MB limit per attachment. Take a look at this page for more information:
Manage hosted feature layers—ArcGIS Online Help | Documentation
Hope that helps!
Best,
Katie
thainamota
Katherine thanks so much
Katie_Clark
You're welcome! Also, since you say you're new to ArcGIS Online I thought I'd share this in case you hadn't heard of it - sounds like it might be useful to you if you're needing dozens of attachments per feature!
https://www.esri.com/arcgis-blog/products/arcgis-online/mapping/use-attachment-viewer/
Best,
Katie
