mobile unit that uses windows?
590
08-13-2025 10:45 AM
LisaCasey
Hi All,
I was wondering if anyone might have a suggestion on a good mobile unit that would run on windows.
We had been using Field Maps on galaxy tablets, which worked well; however now our public works folks want to be able to use VPN and for that, we have to have windows running.
I know field maps will not work on windows; but I was thinking they could use EXB/AGOL directly in Chrome or edge and edit using the web browser.
The problem with their current surface tablets is that the users do not have location services.
I am hoping if we get surface pros with 5G/LTE (i.e. Microsoft Surface Pro 11 5G) that will fix the location issue?
I tried using a cheap GPS dongle from Garmin and no luck in a web browser (but worked great in Google Earth).
THANK YOU for any help or suggestions!!
-Lisa
Tags (3)
RhettZufelt
MVP Notable Contributor
Not direct answer to your question, but I have found that in ExB (and old WAB) if you add the My Location widget, you are able to zoom to your location on GPS enabled devices like iPad/iPhone in the browser.
I don't have GPS enabled windows box to test, but is possible you could go that route.
R_
