Points dropped when converting KMZ layer to a KML and then editing symbology. Why?
486
08-12-2025 03:39 PM
RoseMGrimson
When I went to edit my layer after converting it from a KMZ to a KML file, there was a section of my layer that was dropped. Why might this be? How might I go about solving this issue without converting and re-adding the file? I did the layer conversions within ArcGIS Pro and then published that map to ArcGIS Online as a web map.
I'm new to using map viewer, so these issues might be very straightforward.
Tags (1)
EmilyGeo
Hi @RoseMGrimson
Editing or styling KMLs is not supported in Map Viewer so I'm not sure what could have happened. Can you describe the steps you took, or share a screenshot?
