MDB data to ArcGISOnline
1549
06-18-2013 08:26 AM
tonytony
Is there a way to import a .mdb file to ArcGISOnline?
Trying to show Zip Code data. Data is housed in .mdb
Any info would be awesome
MikeMinami
Esri Notable Contributor
No not from a .mdb...If you have a CSV with lat/long or full addresses, you could add that as a layer to the map.
Or, with a subscription to ArcGIS Online, you could map an Excel spreadsheet with zip codes. Here's a video that shows it.
http://videoembed.esri.com/iframe/1596/000000/width/960/0/00:00:00
Click the link below for more information on Esri Maps for Office
http://www.esri.com/software/arcgis/arcgisonline/apps/esri-maps-for-office
Mike
CarolPark
Export the table as a dBase file then you can incorporate it into a layer on your map.
KathyFlanders
I am having trouble with this too.  I use an mdb file because it allows null values.  I tried exporting to dBASE as suggested but it converted all my null values to zeroes.
If I go the .csv route, will a ",," be recognized the the data is missing, skip to the next field?
P.S. I just tried this.  If I create a column with a couple of cells in which I never entered data, it loads into arc gis online as missing.  However, a column with such missing data can't be used to create a size-gradation symbol map.  If I go back to the csv and delete a value from a cell, then reload the csv into arc gis online, that cells loads in as a zero, not a missing value.
Unless anyone has a better idea I think I will convert the mdb to a shp file, then go in and edit the attribute table, changing what should be a missing value to a large number.  Then I can create the symbol map and change the symbol for that size class to something different, and chage the label for that size class to "no data"
