Maps and Apps Gallery - header icon is squished
3426
09-28-2015 10:33 AM
ChayaBalsiger
I created the Maps and Apps Gallery using ArcGIS Online.  I added an image to be displayed in the top right corner and I like how it looks, but when I added this same image to the Maps and Apps Gallery that I downloaded from GitHub, the image re-sized.
It looks like this in the Maps and Apps Gallery using ArcGIS Online:
and it looks like this in the Maps and Apps Gallery that I am customizing:
Not sure why it shrinks?
ChayaBalsiger
Thanks!  I just changed the "applicationIcon" line of code to look at the location of my image and that solved the problem!
RickeyFight
Chaya,
If you are using the downloaded version, you can edit the css to make the image larger.
The easiest way to do this is with chrome developer tools.
Change the css
Should be around line 774. Change the height to a larger size. You could add
.esriCTApplicationIcon
    height: 48px;
     width: 150px;
    overflow: hidden;
map-and-app-gallery-template/theme.css at master · Esri/map-and-app-gallery-template · GitHub
ChayaBalsiger
