Map viewer vs Classic Map Viewer speed
2375
11-29-2022 02:10 AM
ThomasIllingworth
Good Morning
We have found when testing the same rest endpoint map server in the new map viewer that we find it is rendering slower than when  compared to when putting the same endpoint in classic map viewer. The layer always does render in the new map viewer eventually. We have tried multiple different endpoints on our server and found the same each time
They are coming from a 10.6.1 servers standalone we are planning to upgrade them in the early new year could be related to the servers being an older version.
I was just wondering if anyone else had experienced an issue similar to this?
Thanks
Tom
NicoLuusAU
Yes I certainly have.
Is there any explanation for this behavior? What can we do to improve the Map Viewer.
I'm seeing performance that is much much poorer in the Map Viewer than in Map Viewer Classic using exactly the same set of layers.
nnolasco
I see the same thing, one layer in particular is our feed that comes in from waze, it is MINUTES while classic draws instantly.  The biggest problem is dashboards by default use the new viewer and therefor we are getting poor performance in that as well.
ZachBodenner
MVP Regular Contributor
Definitely notice the same thing as well, especially with moderately sized to larger datasets. No explanation from ESRI yet?
Happy mapping,
- Zach
SimonSchütte_ct
I am observing this not on ArcGIS Online but on Enterprise 10.9.1 with a 25MB polygon layer. It is probably fixed by now in ArcGIS Online.
In the old map viewer it takes half the time to load compared to the new map viewer.
The old Map Viewer first draws the layer and then the basemap.
The new Map Viewer first draws the basemap and then the layer.
